what will happen?
Old Jul 5, 2003 | 09:32 PM
wanttorace's Avatar
Default what will happen?
im doing a ls vtec what will happen if i use the stock oil pump? and suggestions or anyone running ls vtec or crvtec with stock oil pumps?
Old Jul 6, 2003 | 11:41 AM
wanttorace's Avatar
Default Re: what will happen? (jjd493925)
anyone i need some info asap
Old Jul 6, 2003 | 12:06 PM
RHD_BB4T's Avatar
Oil pressure might be a little lower, as it should flow a little less than compared to the VTEC oil pump. I run a turbo'd CR-VTEC, and my oil pressure is within specs across the board with the stock B20 oil pump. I guess some people just want a little more assurance that they won't have a flow problem later on down the line...
HTH
Dan P.
Old Jul 6, 2003 | 10:38 PM
wanttorace's Avatar
Default Re: what will happen? (Dan_P)
thanks alot
Old Jul 6, 2003 | 10:54 PM
inFamousOneSix's Avatar
The oil pressure is within specs because the b20 oil pump is the same as the typer/gsr pumps. The ls pumps flow much less. I'd get a typer/gsr pump for lsvtec, only 100 bucks or so new.
dc4-b20
Mar 10, 2009 09:07 AM
Happyfeat2006
Feb 3, 2009 04:52 PM
civicman69x
Jul 30, 2007 09:04 PM
Battle Cat
Apr 14, 2005 10:04 PM
WAFFLES
Oct 26, 2001 11:48 AM
