what to use when cleaning engine internals?
Old Nov 8, 2003 | 06:31 PM
00b18b's Avatar
Default what to use when cleaning engine internals?
im taking a head apart and just seeing what do you guys or girls use to clean the valvetrain parts? is there some type of bath solution you let the parts soak in?
Old Nov 8, 2003 | 06:36 PM
dwn-shift's Avatar
Default Re: what to use when cleaning engine internals? (00b18b)
I use a cleaner called "Chemtool" you can get it from any auto store. Will eat up hands if you are in contact with it for long, it does the job though.....
Old Nov 8, 2003 | 06:39 PM
mmuller's Avatar
Mad Scientist
Default Re: what to use when cleaning engine internals? (dwn-shift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwn-shift &raquo;</TD></TR><TR><TD CLASS="quote">I use a cleaner called "Chemtool" you can get it from any auto store. Will eat up hands if you are in contact with it for long, it does the job though.....</TD></TR></TABLE>
i use the same, and for big parts i sumerge them in purple cleaner and water
Old Nov 8, 2003 | 06:41 PM
00b18b's Avatar
hmmm "eat up hands" ill remember not to get any on me.....any parts i gotta worry about cleaning with that?
Old Nov 8, 2003 | 06:54 PM
Mohudsolo's Avatar
I've found some of the cleaners will also take paint off so keep it away from the body. I found out when cleaning a valve cover and the paint dissolved. Oops.
Old Nov 8, 2003 | 07:53 PM
McFly's Avatar
Default Re: what to use when cleaning engine internals? (Mohudsolo)
That chemical doesn't sound like it would be very good for the valve seals so be careful of them if you are not already replacing them.
Old Nov 8, 2003 | 08:43 PM
rjardy's Avatar
Default Re: what to use when cleaning engine internals? (McFly)
Gasoline is an amazing cleaner, not the nicest stuff to mess with but effective
Rob
Old Nov 8, 2003 | 08:53 PM
Redline130's Avatar
Default Re: what to use when cleaning engine internals? (rjardy)
I either use Super Clean or brake cleaner.
Old Nov 8, 2003 | 10:18 PM
00b18b's Avatar
how about the valve guides? is it too harsh for it?
Old Nov 9, 2003 | 12:42 PM
00b18b's Avatar
bump
Old Nov 9, 2003 | 05:46 PM
McFly's Avatar
It shouldn't hurt them. Just lube them with some motor oil soon as your done cleaning.
Old Nov 9, 2003 | 07:15 PM
Atheist's Avatar
What about putting it in tool cleaning machines? I saw someone do that on these boards, came out nice and shiney
Old Nov 12, 2003 | 07:46 PM
Adam F's Avatar
Default Re: (Atheist)
parts cleaner solution or brake cleaner
bakomack
Jun 25, 2009 11:43 AM
.BigSexy
Apr 7, 2007 11:28 AM
Schister66
Jan 13, 2006 09:55 AM
vegaskurt
33
Feb 8, 2005 10:04 PM
vtec94
Jun 27, 2003 11:20 PM
