what spark plug wires for my lsvtec?
Old Feb 26, 2004 | 10:36 PM
im a monster hehe's Avatar
Default what spark plug wires + plugs for my lsvtec?
Thanks.
PR3/4 Head
B18B Block
Rpm Activated switch for vtec.
odb0
thanks in advance
Also which spark plugs and gap?
Modified by im a monster hehe at 1:17 AM 2/27/2004
Old Feb 26, 2004 | 10:44 PM
mmuller's Avatar
Mad Scientist
Default Re: what spark plug wires for my lsvtec? (im a monster hehe)
both stock
Old Feb 26, 2004 | 10:55 PM
stock 99 b16a? or???????? stock LS ??????????
Old Feb 26, 2004 | 11:55 PM
Deluzional's Avatar
Default Re: (im a monster hehe)
Si's and Ls use the same spark plug, but wouldn't you want to run a hotter plug for all-motor??? Sorry for the ignorant question, but im a FI guy
Old Feb 27, 2004 | 12:03 AM
Thanks... Which spark plug wires? Same also? Which spark plugs do you suggest.
Old Feb 27, 2004 | 05:44 AM
vtecb20coupe's Avatar
B A N N E D
you can run the stock wires to like 5-600 hp i believe, can't remember where i read that at. and you can go with the oem spec ngk's.
Old Feb 27, 2004 | 03:33 PM
TWoody's Avatar
Default Re: (vtecb20coupe)
Be Sure to check ours out>>
Wires4Cars.com
Cheers,
Old Feb 27, 2004 | 03:42 PM
Ok thanks... Stock wires? From SI or LS? Also which plugs are suggested for LS/VTEC
Old Feb 27, 2004 | 06:12 PM
mmuller's Avatar
Mad Scientist
stock wires for a vtec head.Spark plugs, for your mods...stock
Stock wires have been tested over and over to be the best and more consistent than any others
Old Feb 27, 2004 | 06:13 PM
Deluzional's Avatar
Since you have a vtec head, get wires for an Si. As far as plugs, get Ngk
Old Feb 27, 2004 | 06:56 PM
Kataku2K3's Avatar
Default Re: (Deluzional)
NGK Blues
Old Feb 27, 2004 | 08:13 PM
99lsvtecauto's Avatar
Default Re: (Kataku2K3)
can u use an 99ls header for lsvtec with b16a2 head or do u need an si header
Old Feb 27, 2004 | 08:22 PM
Kataku2K3's Avatar
Default Re: (99lsvtecauto)
Yup, in fact you'll want the LS/ITR header as it is designed for a taller block... You could make a B16 one work tho...
Old Feb 28, 2004 | 01:05 AM
thanks for the help
Old Feb 28, 2004 | 05:46 AM
thanks for reply i bought my header already but i wanted to be sure b4 i start building
Old Feb 28, 2004 | 05:57 AM
i noticed that an si and a type r spark plugwires will not fit on a stock ls the tip that extends from the sparkplug wire is way to long i don't think i was doing it wrong i am running ctr pistons/cams/ 65mm tb jdm 4-1 magnaflow exhaust 12:1 compression ;lsv of course b16a/b18b p28 remapped mallory ignition coil taylor thunder volt itr wires
Old Feb 28, 2004 | 10:47 AM
hmmmmmmmmmmm? what did you use then
Old Feb 28, 2004 | 11:31 AM
RedlinedVTEC's Avatar
Use any OEM B-series wires LS, GSR, Si, ITR, it does not matter they are all the same. For plugs use NGK BKR6E-11
Old Feb 28, 2004 | 07:25 PM
mmuller's Avatar
Mad Scientist
Default Re: (RedlinedVTEC)
yeah, im using ls wires on a vtec head
Old Feb 29, 2004 | 04:31 AM
thanks a million guys
Old Mar 1, 2004 | 03:40 AM
Default Re: (mmuller)
u stil have to use a vtec dizzy obd 2 or obd 1 whatever ecu is right
Old Mar 1, 2004 | 07:37 AM
Kataku2K3's Avatar
Yea, an OBDI or OBDII ECU will work fine with an OBDI/II dizzy (they are interchangable) so just work with whatever one plugs into your harness... nonOBD is the only one NOT interchangable with the others...
Old Mar 1, 2004 | 08:29 AM
You don't have to use a vtec distributor, ls or b20 work fine just need to cut off a leg.
Old Mar 1, 2004 | 10:36 AM
Kataku2K3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">You don't have to use a vtec distributor, ls or b20 work fine just need to cut off a leg.</TD></TR></TABLE>
That's true but it's ugly
LS_VTECteggy
Nov 19, 2009 04:19 PM
rdeezy78
Sep 23, 2008 12:20 PM
piggydog
Nov 12, 2005 05:05 PM
EM1_GIL
Mar 23, 2004 05:31 PM
KF_S2000
Feb 2, 2002 06:08 PM
