what oil?
Old Jan 6, 2003 | 06:22 AM
c3p3r's Avatar
Default what oil?
my mechanic told me mobil 1 (5w-40) is too thin to use in my itr and i should use at least 10w as the b18c doesn't like it.
anyone got any expiriences or thoughts about this?
Old Jan 6, 2003 | 06:28 AM
Spade's Avatar
Default Re: what oil? (c3p3r)
I know that Honda recommends that Civic's use 5w-30. Check your manual.
Old Jan 6, 2003 | 06:35 AM
RaceTilIDie's Avatar
Your oil cap should have the recommended viscosity. Being in cold weather where you are, you want something with a low viscosity, to avoid cold start wear and tear. Unless you have an oil leak and he is recommending against synthetics, because the smaller molecule size.
Old Jan 6, 2003 | 06:44 AM
c3p3r's Avatar
Default Re: what oil? (RaceTilIDie)
I haven't got the stock oil cap or any manuals to tell me either..
I have been looking around on the net but haven't come across anything yet.
I'm in Melbourne, Australia... it's not so cold here.
He said I should use at least 10w-40 but I don't know what the stock item is so i'm a bit unsure now about what oil to use.
Old Jan 6, 2003 | 06:55 AM
I saw Victoria and I thought Canada . Well if it doesn't get cold where you are, I would go with a 10W-30. Even if Honda recommends 5W-30, they will still OK 10W-30 in most cases. 10W-30 is better than 10W-40 in most cases because there are less viscosity modifiers in it.
Old Jan 6, 2003 | 08:45 AM
GOLF_PUNKS's Avatar
i personally recommend 10 40 but you should use valvoline, it works the best, dont bye synthetic just regular valvoline it keeps the motor running real clean
Old Jan 6, 2003 | 10:01 AM
ejprimo's Avatar
also 10w-30 is better than 5w-30 for this same reason.
Old Jan 6, 2003 | 03:17 PM
Kataku2K3's Avatar
Default Re: what oil? (ejprimo)
10W-40 is just harder to thin out when running hotter... For all B series I still just use 10W-30 and Honda MTF for the tranny...
Old Jan 6, 2003 | 03:43 PM
get wet racing's Avatar
Default Re: what oil? (Kataku2K3)
I use mobile 1 15-50, I think it's good cause my car gets realy hot.
Old Jan 6, 2003 | 03:59 PM
97gSrkId88's Avatar
Default Re: what oil? (get wet racing)
all honda should use 5w-30 all year round, it will save you alot of gas mileage.
Old Jan 6, 2003 | 06:43 PM
ejprimo's Avatar
Default Re: what oil? (integrakid88)
if you want to save gas, then why not go to 0w-20.
http://theoildrop.server101.com/ubb/ultimatebb.php is a great fourm about all types of oils.
[Modified by ejprimo, 7:44 PM 1/6/2003]
Old Jan 6, 2003 | 07:07 PM
Shawn C's Avatar
In The Garage
or mineral oil?? (0w0) j/k. i like valvoline or pennzoil 10w30. full synthetic on turbo/high comp. apps, conventional on stock/old engines.
also-- if youre a fan of clean internals- i did a little test at work one day. i took a sample of like 10 top name brands of oil and compared them. valvoline is the clearest conventional oil, and pennzoil is the darkest (purebase w/ dark additive pkg.) so thats one reason why im a valvoline fan.
[Modified by 22lbGS-R, 4:10 AM 1/7/2003]
Old Jan 6, 2003 | 07:20 PM
ejprimo's Avatar
Default Re: what oil? (22lbGS-R)
pennzoil, valvoline, and castrol synthetics are made from a group III basestock, which essentially means it is made from dino oil that has been refined enough to be called a "synthetic".
mobil one is made from a group IV basestock which means it is a true synthetic.
Old Jan 6, 2003 | 07:35 PM
tominos's Avatar
5w30 you'll lose some horses with 1030 b/c it's thicker. i saw in a magazine with a civic and they did a tune up and changed oil with 1030, then dynoed it, numbers were lower than baseline, so they changed the oil, and the numbers jumped back up. i dunno how accurate that is though, i don't have any real experience.
gooblinn258
May 12, 2014 10:54 AM
bowtieboy911
Jul 13, 2011 06:43 AM
adrenalynmike
Honda Civic (2006 - 2015)
Oct 6, 2008 11:51 AM
Khanster
Honda Civic (2001 - 2005)
Sep 13, 2008 08:02 PM
macdaddy
May 9, 2002 06:09 AM
