what makes this noise?
Old May 3, 2007 | 11:10 AM
ekferio's Avatar
Default what makes this noise?
started a few days ago, whenever i'm turning left i hear this low groaning or rumbling noise. i thought it was my exhaust hitting the frame but looks like there's enough clearance all around. Wheel bearings?
Old May 3, 2007 | 01:14 PM
Crispy's Avatar
Default Re: what makes this noise? (ekferio)
wheel bearings would be my guess too, do you have power steering?
Old May 3, 2007 | 04:32 PM
ekferio's Avatar
Default Re: what makes this noise? (Crispy)
yes i have power steering, it's not wheel bearing because i jacked it up and shoke the wheel, there was no play. that noise sounds like something is vibrating under the car. A buzz or rattle
Modified by ekferio at 8:42 PM 5/3/2007
Old May 6, 2007 | 12:15 PM
Crispy's Avatar
a vibration or rattle? I would guess a heat shield that your exhaust may be hitting. Worn engine mounts may cause the exhaust to shift a little when turning maybe?
I asked about power steering because I had a problem in a different car where it would make a groaning whiring noise when I turned the weel. It had something to do with the power steering although I cant remember what.
Correct me if I'm wrong but I thought shaking the wheel was to test your tie-rod ends. a bad wheel bearing may not be so bad that you can shake the rim around.
Old May 6, 2007 | 05:23 PM
ekferio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crispy &raquo;</TD></TR><TR><TD CLASS="quote"> a vibration or rattle? I would guess a heat shield that your exhaust may be hitting. Worn engine mounts may cause the exhaust to shift a little when turning maybe?
Correct me if I'm wrong but I thought shaking the wheel was to test your tie-rod ends. a bad wheel bearing may not be so bad that you can shake the rim around.</TD></TR></TABLE>
Both actually, when it happens i can feel vibration on the floorboard and hear a rumbling or rattling on the passenger side. I thought the exhaust was hitting a heatshield too so i removed the one above the midpipe and one above the header, didn't do a thing. There's one above the resonator which i didn't want to remove because it's supposed to keep heat away from the fuel tank. I'll do some research on the PS noise. I think it's a standard procedure to shake the wheels to test a bad wheel bearing?
Old May 7, 2007 | 03:37 AM
homicydalboy's Avatar
Check your axles. My buddies did that too and his axle was bad.
SiRkid
10
May 26, 2008 08:11 PM
Backk InTheDA
Acura TL, RL & ZDX
Aug 21, 2006 05:48 PM
BANGBANG
Oct 29, 2004 09:35 PM
green98civic
Dec 11, 2003 10:26 AM
kepani
Aug 24, 2003 08:11 AM
