What is this intake manifold & will it work?
I have a CRX with a B16 swap and have been having trouble with emissions. I am pretty sure its something to do with the injectors and vacuum so I cam across this intake and was going to swap the whole thing to see if it made things any better. The problem is that on closer inspection my original intake is very different than the new one. The new one does not have an air temp sensor (connector on the 4th leg), vacuum connections for the charcoal canister, and the map sensor os on the throttle body. Also, this intake has some other kind of connector sitting on top of the fuel rail (dont know what it is) and the fuel rail itself has a completely different end than my current one (current one has a wide end that the fuel line goes around).
Pictures at http://forums.desertlan.com/sh...d=108
Anyone know what this new intake is and if it is possible to make it work with my setup? Thanks in advance!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">thats a b16 im out of a 99 civic si.</TD></TR></TABLE>
YEP
99-00 civic si
YEP
99-00 civic si
Thanks a bunch! Is there a reason to use it vs just swapping the injectors? Also, do I need to worry about the extra sensor on the fuel rail (what is it) and how do I connect the fuel line?
kobeRy_si
11
Jun 6, 2005 03:20 AM
hondacivic4g
Jul 16, 2002 06:51 AM
