what injectors to use?
what injectors should i use in my d15, any injectors from other motors that i should use?
t..
if you want to wash the cylinder linings with fuel and lose compression, sure
go right on ahead
unless you have an ECU that can clock back the injectors
and lean em out if you put in larger ones, you will lose like 20% to the wheels.
not my idea at a fun day at the dynometer
go right on ahead
unless you have an ECU that can clock back the injectorsand lean em out if you put in larger ones, you will lose like 20% to the wheels.
I Like Hondas
May 30, 2008 02:11 PM
B_1_8_hatch
Sep 12, 2003 11:23 AM
