what head on LS(B18B) block for turbo
Old Sep 14, 2002 | 10:34 AM
fuguman's Avatar
New User
Default what head on LS(B18B) block for turbo
I have an LS bottom but no head. I need a head and want to know what my best choice is. i dont want a vtec head because of the high compression and they are pricey.
so far i think my choices are:
* B18A head - i dont know if that will work and what the compression will be
* B18B
* B20 - also dont know if that will work and what the comression will be.
which will be my best choice for compression, availability and price
Old Sep 16, 2002 | 12:13 PM
fuguman's Avatar
New User
Default Re: what head on LS(B18B) block for turbo (fuguman)
Old Sep 16, 2002 | 12:28 PM
X2BOARD's Avatar
Vtec motors only have high compression stock due to the piston... head has some play in it, but very little.
The B18A and B18B heads should yeild the same CR on the block (if the head is not milled) But the B18B has a more efficient head and I/M design, which yields more Hp.
If you have a choice, opt for the B18B.
Old Sep 16, 2002 | 12:31 PM
StyleTEG's Avatar
Isn't the B20 head and the B18B head the same?
Old Sep 16, 2002 | 12:38 PM
X2BOARD's Avatar
Default Re: what head on LS(B18B) block for turbo (StyleTEG)
I would say yes, but not definite. Would the combustion chamber be a little larger on the B20 to accomodate the increase in bore ? (Which would also lower CR.)
X2
Jillianbowman87
16
Oct 17, 2011 01:24 PM
juicedricer
19
Jan 19, 2011 08:37 PM
fuguman
Sep 16, 2002 12:14 PM
fuguman
Sep 14, 2002 01:54 PM
Chuji
Sep 6, 2001 05:25 PM
