what head bolts to use for ls/vtec????
Old Aug 2, 2002 | 06:02 AM
jdmhatch94's Avatar
Default what head bolts to use for ls/vtec????
i have a b18a block and a 00' b16a2 head i dunno if i should use the b16a bolts or the gsr head bots??
thakns
will
Old Aug 2, 2002 | 07:57 AM
BROOD's Avatar
Default Re: what head bolts to use for ls/vtec???? (jdmhatch94)
Well I'm using ARP head studs for a B16A engine on my LSVT. So I'm positive B16A headbolts will work fine for you.
Old Aug 2, 2002 | 08:50 AM
Jeff C's Avatar
the b16 ones should be fine if you are not making mega power, but people have recommended using the gsr because they are a little longer
Old Aug 2, 2002 | 10:25 AM
slickboy's Avatar
New User
Default Re: what head bolts to use for ls/vtec???? (Jeff C)
ARP VTEC head studs
Old Aug 2, 2002 | 11:02 AM
WAFFLES's Avatar
Default Re: what head bolts to use for ls/vtec???? (slickboy)
DO NOT use B16A headstuds. They are about a 1/4" too short. Use either GSR or ARP GSR headstuds. Running the b16 headbolts will increase teh likelyhood of blowing a headgasket.
[Modified by WAFFLES, 2:02 PM 8/2/2002]
Old Aug 2, 2002 | 11:20 AM
Kamin's Avatar
Default Re: what head bolts to use for ls/vtec???? (WAFFLES)
ARP
dont build it half assed.
Old Aug 2, 2002 | 11:53 AM
WAFFLES's Avatar
Default Re: what head bolts to use for ls/vtec???? (KAMiN)
ARP
w3rd
Old Aug 2, 2002 | 12:38 PM
g's integ's Avatar
Will LS rod bolts do?
Old Aug 2, 2002 | 12:55 PM
WAFFLES's Avatar
Default Re: what head bolts to use for ls/vtec???? (g'sinteg)
not recommended
Old Aug 2, 2002 | 01:00 PM
g's integ's Avatar
thanks
Old Aug 2, 2002 | 01:03 PM
DLB1994's Avatar
use gsr 1.8 head studs
Old Aug 2, 2002 | 11:06 PM
tinkerbell's Avatar
Default Re: what head bolts to use for ls/vtec???? (DLB1994)
can i just jump in and say:
if you want to, use ARP GSR head studs (PN 208-4303) and ARP 8mm LS rod bolts (PN 208-6001).
these fit teh B20VTEC and LS/VTEC engine.
t..
[Modified by tinkerbell, 6:07 PM 8/3/2002]
Old Aug 3, 2002 | 04:57 PM
junya16's Avatar
if you're gonna do it you may as well do it right
go with arp, i have ls/vtec and have had no blown headgaskets and everything is runnin good
cinder0159
Apr 16, 2011 07:10 PM
brian3676
Dec 14, 2005 05:45 PM
SPOOLINmatt
Apr 8, 2005 12:40 PM
paulzy
Nov 9, 2001 03:41 AM
jboostedhatch
May 2, 2001 09:56 PM
