what causes a tps code?
Old Oct 10, 2005 | 07:54 PM
Keith Pierson's bitch's Avatar
Default what causes a tps code?
my b16a is throwing a tps code.. any ideas on the cause?
Old Oct 10, 2005 | 07:56 PM
Lord Helmet's Avatar
Default Re: what causes a tps code? (xxturbodreamsxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxturbodreamsxx &raquo;</TD></TR><TR><TD CLASS="quote">my b16a is throwing a tps code.. any ideas on the cause?</TD></TR></TABLE>
either it's bad or you need to adjust it to factory specs.
Old Oct 10, 2005 | 08:10 PM
Default Re: what causes a tps code? (Lord Helmet)
it is on a skunk2 throttle body... would that make a difference? also, the check engine light doesnt come on until you go into higher rpms... under normal driving its fine
Old Oct 10, 2005 | 09:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxturbodreamsxx &raquo;</TD></TR><TR><TD CLASS="quote">it is on a skunk2 throttle body... would that make a difference? also, the check engine light doesnt come on until you go into higher rpms... under normal driving its fine</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet &raquo;</TD></TR><TR><TD CLASS="quote">
either it's bad or you need to adjust it to factory specs. </TD></TR></TABLE>
Old Oct 11, 2005 | 10:09 AM
T.J.'s Avatar
see if your running the correct voltage to it.
Old Oct 12, 2005 | 07:17 PM
mtber's Avatar
Default Re: what causes a tps code? (T.J.)
My guess is going to be that the tps is out of adjustment.
Get a helms manual & a voltmeter. Probe the middle wire on the tps connector according to the helms manual. You will probably have to rotate the tps to get the tps voltage into spec.
egkid386
Sep 29, 2008 07:39 AM
Quickridez_3
Dec 16, 2006 05:02 PM
EF_ST@TUS
10
Aug 19, 2005 07:17 AM
djgalloway73
May 11, 2005 05:08 PM
preluder
May 29, 2003 07:03 PM
