what are the causes of dropping and snapping valves
Old Jul 7, 2003 | 06:32 PM
jansenrw's Avatar
Default what are the causes of dropping and snapping valves
as title states... would like any imput....
I just pulled the motor apart and #3 cylinder is sporting 2 broken valves, chunks missing out of the head and scores on the bore!!! go figure???
is it tuning, too high rpm??? what else
Old Jul 7, 2003 | 06:50 PM
altoid's Avatar
Default Re: what are the causes of dropping and snapping valves (jansenrw)
what mods are done to the engine
Old Jul 7, 2003 | 06:53 PM
jansenrw's Avatar
check sig... anything else??
Old Jul 7, 2003 | 07:09 PM
altoid's Avatar
Default Re: (jansenrw)
why do you have a turbo timer in a 12.4:1 all motor application.....
Old Jul 7, 2003 | 08:50 PM
jansenrw's Avatar
a/f ratios anyway can anyone answer my Q????
Old Jul 7, 2003 | 09:17 PM
MikeSarr_GSR's Avatar
missed shifts
broken valve retainers
improper installation of valvetrain/timing belt
piston/rocker arm binding due to insufficient oil pressure causing valvetrain
to stop and pistons to keep moving. code 22 may be a foreshadowing of this.
improperly installed cams
improper cam gear settings, high rpm
sustained high rpms with improperly lashed valves on agressive cams
binding valvetrain
unchecked piston to valve clearance at ultimate valve lift
and rod stretch at top engine operating speed
there are some ideas. sorry to hear about the bad news
Modified by MikeSarr_GSR at 1:28 AM 7/8/2003
Old Jul 7, 2003 | 09:46 PM
altoid's Avatar
Default Re: (MikeSarr_GSR)
you mean those nifty things that keep the car running after you turn off your car does stuff for your a/f ratios? you sure you mean turbo timer?
Old Jul 8, 2003 | 01:27 AM
jansenrw's Avatar
altoid... my mods have been researched.. I'm absolutley sure about the a/f ratios.. infact apexi primarily brought it out as an a/f meter and added the timer option.. comprende???
MikeSarr_GSR
THANK_YOU!!!!!!
Old Jul 8, 2003 | 09:12 AM
under the circumstances, glad I could help
twentyhurtz
Sep 15, 2009 10:38 AM
evildc2
Jul 31, 2008 01:38 PM
RSX_S
May 20, 2008 11:32 AM
smokey2.0
Dec 27, 2003 05:18 AM
Halo
May 22, 2002 09:03 PM
