what cause low vac on boost gauge?....
i was wondering what cause low vac on my boost gauge?...bout 3 days ago it was reading 20-23 hg. and it was park ever since...i havn't touch or drove the car until today, i cranked it up,let it warm up and now its reading 10 hg...
id checked for vaccum leak and thers no sign... any tips would help...
well i was having problem w/ the surging...but it was reading 20-23 hg when it was surging 3 days ago...still surging and now reading 10 hg...the idle is pretty smooth...its reading 10 hg from cold to fully warm..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner »</TD></TR><TR><TD CLASS="quote">sounds like a leak to me, thats the about what i read when I leave something unhooked.</TD></TR></TABLE>
id check and no leak...id change the IM and tb gasket too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted EM1 »</TD></TR><TR><TD CLASS="quote">vacuum leak is the only thing i could picture.... is your idle up and down, because i get that alot with mine and somebody had mentioned it? </TD></TR></TABLE>
yea it idles betwen 800-1200 rpm....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 »</TD></TR><TR><TD CLASS="quote">vac leak or compression</TD></TR></TABLE>
i havn't do a leak down check on it,but i did a compression test on it and it was 185 psi across the board..
so pretty much if you have a vacuum leak your idle is going to be really low and rough... because you arent getting enough air and that cause the engine to run super rich??? later Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowhonduh93 »</TD></TR><TR><TD CLASS="quote">so pretty much if you have a vacuum leak your idle is going to be really low and rough... because you arent getting enough air and that cause the engine to run super rich??? later Mike</TD></TR></TABLE>
No, a vacuum leak wopuld mean it's getting too much air. The idle speed would be higher or bouncing. Running lean more likely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
No, a vacuum leak wopuld mean it's getting too much air. The idle speed would be higher or bouncing. Running lean more likely.</TD></TR></TABLE>
yea but my idle is pretty smooth...
whats your base ignition timing at becasue if you are running a low base timing it will cause a low vacuume, also do you have camgears becasue excessive retardation of the cams either one will cause low vacuume. compression also, like allready stated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest »</TD></TR><TR><TD CLASS="quote">whats your base ignition timing at becasue if you are running a low base timing it will cause a low vacuume, also do you have camgears becasue excessive retardation of the cams either one will cause low vacuume. compression also, like allready stated.</TD></TR></TABLE>
my ign is set at stock...and the cam gears are at 0 deree...
Eskay@JDMCircle.com
Oct 6, 2004 09:43 PM
