Weird Clutch Problem
Old Dec 28, 2006 | 10:09 AM
b16pwrdeg's Avatar
Default Weird Clutch Problem
Recently installed a OmniPower Quiclutch Master Cylinder, new slave cylinder, and replaced the soft rubber hose with a InlineFour Stainless Steel line. System has been bled numerous times, but the following problem still persists:
-When the car sits overnight and is cold, the clutch pedal "creeps" lower, almost to the floor.
-To get the pedal back to where it should be I stick my foot under it and pull it up and it stays.
-When the car is cold, it is hard to get into 1st and 2nd gear, however, when it warms up it goes into gear like it should.
The transmission does leak a small amount of fluid due to a messed up axle seal.
Any help or suggestions is appreciated.
Old Dec 30, 2006 | 11:38 AM
b16pwrdeg's Avatar
Bump for some help
Old Dec 30, 2006 | 06:41 PM
igotthaspirit's Avatar
Default Re: (b16pwrdeg)
Does it leak any fluid from the clutch system? What kind of fluid did you use. Supposed to be Honda OEM Brake fluid.
Old Dec 31, 2006 | 06:28 AM
b16pwrdeg's Avatar
I checked for leaks and haven't noticed any. I put DOT 3 fluid in it, but not Honda OEM.
Old Dec 31, 2006 | 06:38 AM
you may have got a bad master cylinder. sounds like fluid is leaking by the seals when they get cold. put a space heater by the master cylinder over night then see if it acts up in the mornin
Old Dec 31, 2006 | 06:49 AM
b16pwrdeg's Avatar
Thanks for the help. I will try it
deeweezy187
Jan 5, 2008 10:04 AM
zapa47
Nov 21, 2006 09:17 AM
tytyguy
Dec 3, 2005 02:32 AM
carlosd68
May 14, 2005 10:14 PM
juniordc2
Jul 2, 2002 08:33 AM
