weird check engine light problem help!!!
Old Dec 11, 2011 | 04:50 AM
xlusiveracer's Avatar
Default weird check engine light problem help!!!
the car is a poormans type r in a 95 coupe.when i turn the car no light pops up but when i put the pin in the plug to check what code it the engine light would pop up and stay solid and the srs light would start blinking.what would be the problem with this?
Old Dec 11, 2011 | 05:13 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: weird check engine light problem help!!!
Solid light when checking the codes means you have no stored codes. If the light is coming on while driving, find a safe place to pull over, keep the car running then check the light and see if it gives you a series of blinks.
Old Dec 11, 2011 | 05:26 AM
doesnt blink at all when running.but cold mornings when i start it it wouldnt be there until it gets a lil warm if that helps anything.
Old Dec 11, 2011 | 07:29 AM
just looked and it came out to be 4 blinks 1 short.primary oxygen sensor heater how do i fix this anyone?
Old Dec 14, 2011 | 05:15 PM
The Survivor's Avatar
You go and buy another oxygen sensor. There is no way just to fix the heater. You don't have to fix this. The only time it will affect you is when the car is cold. It takes longer for the O2 sensor to warm up thus causing the car to stay in open loop longer resulting in crappier gas mileage for the duration it takes for it to warm up. It just boils down to how bad you want the cel to be fixed.
Old Feb 8, 2012 | 05:59 AM
phantum's Avatar
Icon6 Re: weird check engine light problem help!!!
I have the same issue ,boosted running close loop my cel come on at 60 deg and below. I have to when warm shut down and restart to go into closed loop then no light.
Mitch Rosner
Dec 27, 2011 09:12 AM
hondagall10
Aug 21, 2010 07:08 PM
marinersfaninmd
Acura TSX
Jun 15, 2009 07:24 PM
Spartoons
Jul 9, 2007 05:44 PM
Preludegirl
Dec 3, 2003 08:14 AM
