want opinion and suggestions
Old Dec 30, 2009 | 03:12 AM
precise's Avatar
New User
Default want opinion and suggestions
built a all motor ls
puttin stage 2 cams and gsr pistons...wat u guys thinks???wat kind injectors,fuel pump and bolt ons should i do to get a decent all motor ls...lmk
Old Dec 30, 2009 | 04:48 AM
GhostAccord's Avatar
Default Re: want opinion and suggestions
Something that makes use of the stage 2 cams power band would be a good place to start. If you know what that is it would help make things easier.
Without stating what the use of the car. power goals or the cams specs. It's hard to say weather you should go with 310cc injectors or 450s, a smaller 4-2-1 Tri-Y header or a big tube 4-1 header.
What size is your throttle body and have you done anything to upgrade the flow of air through the head other than adding a random stage 2 cam?
Old Dec 30, 2009 | 08:12 AM
TWINK1E's Avatar
if youre going to stay ls and want to see impressive numbers you should use a stroker kit.
Old Dec 30, 2009 | 08:54 AM
precise's Avatar
New User
I GOT 4-1 DC HEADERS,STOCK THROTTLE BODY,STAGE 3 CLUTCH,STOCK INTAKE MANIFOLD AND STOCK ECU...SHOULD I PUT GSR TRANS AND PISTONS???
RP215.
Jun 1, 2007 05:17 PM
RaceCarRyne
Jan 14, 2006 07:14 AM
HobbesGSR
Apr 19, 2005 03:16 AM
91integraLSVTEC
Sep 28, 2004 07:21 PM
ActiveAero
Jan 18, 2004 10:03 AM
