Vtec problem on J-spec b16a
Old Nov 19, 2002 | 07:54 PM
buzz_worthy321's Avatar
Default Vtec problem on J-spec b16a
I have checked wiring.. oil level is good... any suggestions
Old Nov 19, 2002 | 08:08 PM
91SIR's Avatar
Default Re: Vtec problem on J-spec b16a (buzz_worthy321)
may be the speed sensor
Old Nov 19, 2002 | 08:46 PM
Katman's Avatar
lol. wth? can you be any more specific about your vtec troubles? haha..
are you getting any check engine lights?
what exactly is the problem you're experiencing?
...need......more.....info.....
Old Nov 20, 2002 | 04:35 PM
Default Re: Vtec problem on J-spec b16a (Katman)
it is throwing a 9 and 4 code adn vtec isn't working.... at all.... I don't have a speed cable.... but will have one this coming monday...
Old Nov 20, 2002 | 04:36 PM
yes i have check engine light.....
Old Nov 20, 2002 | 05:13 PM
Racerj404's Avatar
what wiring harness do you have? my friend had the same problem with the place racing harness and the instructions were wrong, and a wire got hooked up wrong.
Old Nov 20, 2002 | 05:22 PM
and when i press the gast to the floor the engine bogs down
Old Nov 20, 2002 | 09:10 PM
dr650's Avatar
New User
thats it rev pass 4gz ? if not check ur timing belt<<make sure everything lines up.if its good then is your distributor.th
01em2slvr
Honda Civic (2001 - 2005)
Nov 11, 2009 12:43 PM
sleepingeg6
Nov 13, 2005 10:40 PM
JDMBoi
Apr 26, 2005 02:16 PM
DasaEJ1
Jan 24, 2005 05:15 PM
shorty
May 12, 2003 07:06 PM
