Vss troubles help
Old May 2, 2013 | 11:17 AM
CiViCShella's Avatar
Default Vss troubles help
So my cel light came on when I was driving and my speedometer briefly went out . Went to aap and did a diagnostics check that my vss ( vehicle speed sensor ) was out. ( as I suspected ) parts coming in two days. But my speedometer is working again as my cel lights still on . I still have to do emissions so not sure if I need this sensor to clear the code.
Also can't seem to find where my vss is actually located . Help ? Please ?
Old May 2, 2013 | 01:16 PM
jdmh22eg2's Avatar
Default Re: Vss troubles help
clear the code. go to under hood fuse box pull fuse labeled "back up" pull this fuse for 10 sec, put back in should be golden.
many ppl will tell you pull ecu fuse, some times that works but most of the time to 100% sure pull the back up fuse
Old May 2, 2013 | 01:18 PM
JuggerNaut-CTR's Avatar
vss is located on top of the trans
More times than not, there is a dirty/corroded contact(s) on the sensor plug causing a contact issue
Old May 2, 2013 | 01:29 PM
Thank you so much gonna try it out
Old May 2, 2013 | 01:37 PM
Worked thank you so much , I'm not gonna be running codes still am I?
Old May 2, 2013 | 01:44 PM
jdmh22eg2's Avatar
If you are saying it worked and directed at me about question. No you cleared codes, it will only come back if there is a further issue
jrami020
Oct 18, 2009 02:24 PM
pacey
12
Aug 18, 2009 11:24 PM
suzuki1211
Dec 30, 2008 11:33 AM
_Bug_
13
Feb 22, 2006 07:30 AM
delsolcrazy
May 5, 2005 03:06 PM
