Vss help after tranny swap
Old Oct 11, 2008 | 10:33 AM
JordanCivic's Avatar
Default Vss help after tranny swap
Hi guys,
I swapped the S4C tranny for a S9B LSD, the 2 VSS are different types, one a long one with a gear on the bottom and one bolt mount, the other a short 2 bolt item with no gear. Both same electrical connector.
Speedo not working after swap and im having trouble finding a different VSS for the new box. I also have code 17 vss.
Question - Is the wiring different on these 2 different VSS's ?
Craig
Old Oct 12, 2008 | 02:47 AM
Ok guys, swapped for another VSS and still the same.
Is there any differences at all in the wiring/pinout of these 2 types?
Old Oct 12, 2008 | 09:08 AM
dtapia's Avatar
Default Re: (JordanCivic)
must be if you give the year and make of the vss used i can get the correct location .
Old Oct 12, 2008 | 09:35 AM
Problem solved. The centre pin on the harness side is slightly damaged. Fixed and working.
Cheers
Old Oct 25, 2008 | 08:50 PM
nolimitdc2's Avatar
hey i have a question about a posting that you did. I have a 2000 acura integra gsr, i have removed my tranny from my integra and the speed sensor connector was attached to the tranny when we were pulling the tranny off of the motor. and the wires where pulled of the connnector, and the possitions to the 3 pins are almost impossible to find. i have tryied using alldata and there are no connector views and not even acura dealership could help me. i have the one connector with the BLUE/WHITE, BLACK, BLACK/YELLOW wires. and i may have shorted the speed guage by trying to guess the possitions. I want to get a guage cluster but i dont wanna short that one out aswell. SO MY QUESTION IS, DO YOU KNOW THE POSSITIONS OF THE THREE WIRES THAT GO INTO THE CONNECTOR?
Old Oct 25, 2008 | 10:47 PM
Do a search here for'vss wiring'.
There is quite afew posts in the archive.
Good luck mate
jose310
Mar 12, 2009 02:14 PM
spiderhatch
Dec 1, 2007 04:27 PM
X_Josh411_X
Sep 27, 2005 05:57 PM
