vigor one cylinder does not work, HELP!!
Old Aug 1, 2002 | 10:28 PM
NZcrx88's Avatar
Default vigor one cylinder does not work, HELP!!
honda vigor 1990 , one cylinder does not work. it happened a few days ago and i felt that the car became trembling a little bit , I pulled THIS spark plug connection out and engine just nothing changed, but when i pulled any one of others, idle became much lower, i checked the spark, 4 of them were perfect and just this one was in white colour. What happens to this? Is it a engine problem? please help, thanks!
Old Aug 2, 2002 | 02:16 AM
88_SC_CRX_Si's Avatar
New User
Default Re: vigor one cylinder does not work, HELP!! (NZcrx88)
Is it throwing any codes?
White or new clean looking plug(s), usually is a sign that it's running too lean on that cyclinder(s). Take a screw driver, place the flat end against the injector of the above mentioned cylinder, and the handle against your ear and listen, while you rev the engine up and down. Now do that to the others, and compare sound. That will help tell you if that injector is working. Another would be switching/swapping out that plug wire, to see if that changes anything.
Old Aug 2, 2002 | 07:51 AM
Gennady's Avatar
New User
It could be the plug, or wire, or something going all the way back to the distributor like a faulty rotor.
Old Aug 2, 2002 | 12:27 PM
NZcrx88's Avatar
Default Re: vigor one cylinder does not work, HELP!! (88_SC_CRX_Si)
Thanks
i did that last night but i just could not find the different, i may put a wrong place
Old Aug 2, 2002 | 01:33 PM
Kamin's Avatar
please dont post this multiple times in the same forum.
Old Aug 2, 2002 | 02:15 PM
NZcrx88's Avatar
Default Re: vigor one cylinder does not work, HELP!! (KAMiN)
Thank you for your advice
sorry for that and i just want to have more info
EGtyper94
26
Apr 16, 2008 09:24 AM
NZcrx88
Aug 2, 2002 02:03 PM
NZcrx88
Acura TL, RL & ZDX
Aug 2, 2002 08:35 AM
NZcrx88
Aug 2, 2002 01:46 AM
NZcrx88
Acura TL, RL & ZDX
Aug 1, 2002 11:32 PM
