victor x intake manifold ?
Old May 25, 2003 | 04:44 PM
b20cx's Avatar
Default victor x intake manifold ?
I`m runnig a b20 with a b16a head (not ported),JUN stage 3 cam, a JDM DC Sports headers, 11.5/1 of compression, Hondata= 195.7whp at 7700rpm and 143.1wt at 6100rpm. Then we bolt-on the Victor X intake manifold to replace the stock one =189.7whp at 8700(my curent cut-off) and 140.5wt at 6100rpm.Is it possible that this intake is not for my set-up OR can I have better results with more cam tunnig. I dont know alot about flow theory so if you can explain me how cam tunnig could or could not change those results with the Victor X it would be very COOL. THANKS ...
Old May 25, 2003 | 06:12 PM
Ruby Civic's Avatar
Default Re: victor x intake manifold ? (b20cx)
that would be the general experience, and can you imagine if you only had a b16? if your cams are designed for high rpms that will be all of the diff. if you can go up past 9k with cams still doing ok
Old May 25, 2003 | 06:13 PM
Ruby Civic's Avatar
Default Re: victor x intake manifold ? (Ruby Civic)
my bad, saw you have jun 3's - did you get good dyno tuning on that with air/fuel ratios, etc.??
Old May 25, 2003 | 06:31 PM
b20cx's Avatar
last summer we did but we lowered the compression so now it is runnig too ritch.but I was thinking that BOLT-ON the VICTOR X would work well , then do the fine tunnig.
Old May 25, 2003 | 10:28 PM
smokey2.0's Avatar
this is o/t, what have you done to the bottom end? girdle? arp rod bolts? etc...
Old May 26, 2003 | 05:44 AM
b20cx's Avatar
GSR girdle .Eagle H-Beam rods, Arias pistons,ARP head stud, sleeved closed deck; but it dont answer my problem...
Old May 26, 2003 | 08:01 AM
WundedSaint's Avatar
Did you change your fuel map and added more fuel? Maybe you're running a little lean on your fuel map.
Old May 26, 2003 | 08:19 AM
hndarcrb18c1's Avatar
Default Re: victor x intake manifold ? (WundedSaint)
That manifold is good for turbo cars we gained 40whp but we have always lost Hp on all motor cars....
Old May 26, 2003 | 08:21 AM
dfoxengr's Avatar
its a turbo manifold
Old May 26, 2003 | 08:22 AM
dfoxengr's Avatar
Default Re: victor x intake manifold ? (hybridvteceg)
skunk2 for NA
Old May 26, 2003 | 08:27 AM
smokey2.0's Avatar
Default Re: (b20cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20cx &raquo;</TD></TR><TR><TD CLASS="quote">GSR girdle .Eagle H-Beam rods, Arias pistons,ARP head stud, sleeved closed deck; but it dont answer my problem...</TD></TR></TABLE>
thankx for the info, but from what i have heard that manifold is best suttted for FI applications. i was hopeing that with a 2.0 displacement, it would help a N/A engine. one thing i would question, is if raising the CR will affect how the manifold works in the N/A application. my .02c
Old May 26, 2003 | 10:07 AM
b20cx's Avatar
Thursday I`m going back to the dyno with my tuner(www.autolaminar.com) and I will post you the results. He thinks that with good tunnig the victor X will work find but it will move up the powerband. If you have dyno run of the victor X could you post it for me(not the one in the Turbo Magazine,I already seen it) THANKS
Old May 26, 2003 | 11:45 AM
Ruby Civic's Avatar
Default Re: (b20cx)
jun iii's like toda b's need that compression, most reporting need of 11.5 CR or above...maybe that is part of it
keep us posted
Old May 26, 2003 | 03:56 PM
b20cx's Avatar
By the time, the runners on the Victor X are 16cm from the head to the chamber.
BearsEK-KMSU
55
Dec 7, 2007 11:18 AM
hatchish
Jan 10, 2006 08:41 PM
-Whitey-
10
Dec 27, 2002 12:30 PM
DocV
Dec 27, 2001 09:38 AM
TypeR0149
Dec 10, 2001 12:19 PM
