Vibration in my car
Old Nov 16, 2004 | 09:42 AM
EFin' Kyle's Avatar
Default Vibration in my car
ok well latly i have picked up a vibration. i though it was the crank pully cuz that is where it sounded like it was coming from. but i realized it doesnt have a vibration when i rev it up with either the clutch in or in neutral. so it cant be the crank pully, crank, rods, etc... right? it goes by my speed ike the vibration starts to kick in at about 5k in first then for the rest of the gears. but its not that bad in 5th gear. also it doesnt vibrate in gear when slowing down or maintaining speed. only when i accelerate. please help me fix this. thank you
-Kyle
Old Nov 16, 2004 | 11:19 AM
derekcarr's Avatar
Default Re: Vibration in my car (crxstreetracer90)
Could be something simple like you threw a wheel weight or you can have an axle starting to go. When you are at speed try taking out of gear and see if the vibration is still there. If it is not I would be more suspect of the alxe.
Derek
Old Nov 16, 2004 | 12:59 PM
tirapeo's Avatar
You may want to balance your tires or switch the front wheels to the back to get a quicker result.
Old Nov 16, 2004 | 04:20 PM
EFin' Kyle's Avatar
Default Re: Vibration in my car (tirapeo)
it doesnt vibrate ever when it is not in gear. only when in gear accelerating. so axel? or could it still be a weight? also how do i check if its a weight? i dont think its an axel becuz when i have had one go bad it clicks when i turn and it doesnt do that. thank you so far everyone fir the tips and help
-Kyle
Old Nov 16, 2004 | 05:14 PM
atcrx's Avatar
sounds like a wheel weight. Rotate your tires & see if it gets better. Or take it to a tire store & have them re-balance your tires. Should not cost vey much to do that.
Old Nov 17, 2004 | 10:47 AM
EFin' Kyle's Avatar
Default Re: Vibration in my car (atcrx)
i rotated the tires and its still there. not as bad but still affects the steering as if it is in the left front. umm.... when i took the tire off it has a spot in the tire about an inch wide all the way around where the threads are showing. this is a camber problem right just have it alligned or what? also could that cause the vibration?
-Kyle
Old Nov 17, 2004 | 10:59 AM
EFin' Kyle's Avatar
oh i forgot to ask.... i havea grind in my tranny and i think maybe my tranny is going bad and it needs a rebuild. could there be somthin in the tranny to cause an axel to vibrate?
-Justin-
Feb 1, 2010 01:52 PM
Samuels
Aug 15, 2009 05:57 PM
jt-sport
Aug 13, 2007 04:38 PM
david90
Sep 29, 2003 03:15 AM
