Valvespring install
Old Oct 27, 2002 | 04:23 PM
CivicEx95's Avatar
Default Valvespring install
My car currently is sitting with the cams removed, waiting for that snapon tool to come so I can install my ITR valvesprings and cams into my GSR. Is there anything I need to watch out for when doing the install?
I have a hose from a compression gauge that I'm going to use to shoot compressed air into the cylinders so I don't drop the valves. How much pressure, and do I keep it constantly on? What about draining the oil when doing this?
I also looked at the keepers, and this is the only thing that holds the valve up when reving to 8500? Jeez, what a scary thought, but I guess honda knows what they're doing. Let me know if I should pay special attention to anything so I don't mess things up. Thanks.
My car right now
Old Oct 27, 2002 | 04:34 PM
IN VTEC's Avatar
Default Re: Valvespring install (CivicEx95)
Magnetic pick up tool is a must.
Plug up the oil drain galleries with rags, or you'll be fishing for that keeper.
Old Oct 27, 2002 | 06:42 PM
delslow94's Avatar
where do u apply the air to keep the valves up (ie where do u introduce the air into the chamber)? im soon to be doing the same thing so this would help me a ton
Old Oct 27, 2002 | 06:58 PM
Chugger's Avatar
Default Re: Valvespring install (delslow94)
apply air to the cylinders through the spark plugs holes. i usally keep 100psi at all times and yes a magnet is a must. yes good idea about putting rags in the holes will save yourself a big headache. i used my fingers for the installation of the keepers but a big or small set of tweezers works well.
good luck and take your time.
remember paint up
blue=exhaust
orange/red/yellow=intake
Old Oct 27, 2002 | 11:39 PM
CivicEx95's Avatar
Default Re: Valvespring install (Chugger)
good info chugger. I'm so paranoid that the keepers won't hold for some reason and when I rev to 8k+ it'll all just blow up, but I guess it's just because I've never done this sort of thing before. I'll let you all know how it goes
[Modified by CivicEx95, 12:40 AM 10/28/2002]
Old Oct 28, 2002 | 06:46 AM
Crazydave's Avatar
Also put something down around your engine bay..
to keep them from falling down in bay.. it's a REAL PITA to find them once they have fallen.
if this is your first time installing springs.. those retainers will fly.. they will fall and you will cuss at them
hint : A pick set and be handy sometime too
[Modified by Crazydave, 7:47 AM 10/28/2002]
Old Oct 28, 2002 | 07:21 AM
acura_typer's Avatar
Banned
Good, you're doing everything right. Keep the pressure at 50-60 psi, that is plenty. Make sure the car is in gear, and the emergency brake is on.
Before you try and compress the spring to remove it, take a large socket put it on the retainer and tap it with a hammer. This will jar the retainer loose. Not too hard, or the keepers will pop right out. Make sure the air is on when you do this.
Ohh, and why you are there, might as well do new valve stem seals.
Old Oct 28, 2002 | 12:26 PM
CivicEx95's Avatar
Default Re: Valvespring install (acura_typer)
what about draining the oil?
mynameizstitch
Northern California
10
Jul 16, 2009 07:36 PM
85mm LS VTEC
Sep 12, 2004 09:50 PM
95 Gizzer
Jan 22, 2003 09:18 AM
95integragsr1984
Dec 16, 2002 06:56 AM
