Valve Train Questions
Old Nov 13, 2001 | 07:12 AM
Chuji's Avatar
Default Valve Train Questions
Im going to be using crower 1mm oversized intake and exhaust valves on an LS head. Im also using the duel springs and titanium retainers. My question is, is it recommended to get aftermarket valve stem seals and valve guides? Or is stock ok?
Old Nov 13, 2001 | 07:26 AM
Spade's Avatar
Default Re: Valve Train Questions (Chuji)
new stem seals and valve guides.
Old Nov 13, 2001 | 07:35 AM
Chuji's Avatar
Default Re: Valve Train Questions (Spade)
I know I need new ones but should I use factory new ones or aftermarket?
Old Nov 13, 2001 | 07:37 AM
Spade's Avatar
if you are buying new ones then I would go with aftermarket.
What rev are you hoping for? If you are trying for higher than stock then go with the high quality guides.
Old Nov 13, 2001 | 07:42 AM
Chuji's Avatar
Im planning on revving it as high as LS cams make good power. What aftermarket companies make guides. I also need to replace the valve stem seals. Can these remain stock or should these be aftermarket also?
Old Nov 13, 2001 | 07:57 AM
Spade's Avatar
Here is a link for the seals.... http://www.compcams.com/catalog/313.html ....I have not been able to find any place for the guides right now.....seen them custom of course......I will keep looking.
Chuji's Avatar
Thanks
djnikko
Nov 17, 2006 06:05 AM
E46M3CB
Mar 8, 2004 08:54 AM
hotintegranights
Feb 10, 2003 04:09 PM
