valve adjustment
Yes I would at least take the time to check them all. I would have to say they will probably be off. What ever cam you choose will ( or should ) have the spec sheet to help you set the lash
Good Luck
Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RageDzine »</TD></TR><TR><TD CLASS="quote">Yes I would at least take the time to check them all. I would have to say they will probably be off. What ever cam you choose will ( or should ) have the spec sheet to help you set the lash
Good Luck</TD></TR></TABLE> word to that my homie right there
would not getting them adjusted cause my engine to sound really loud and smoke a little, cause thats kinda whats happening. Im going to get a valve spring adjustment today but im just making sure that nothing else could be the problem.
I dont know about smoking a little, but it could definitely cause it to be noisy, depending on the type of noise. loose valve lash will make the engine very clicky.
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
yes valve adjustment is necc. was a valve job done? if so the valves will sit in the seats farther causing the valve lash to slightly loosen. as far as the smoke i would tend to say valve stem seals
ok i read the civic repair manual
and i sitll dont get it
what kind of tools do u need to adjust valve lash, and how do u physicaly do it? do u just screw the bolt until it touches the valvestem when the valve is in its resting place?
i dun get it
i dun get it
Racewerkz
Jan 26, 2011 07:55 AM
Eyal 951
18
Nov 20, 2007 12:48 AM
ultimatehonda
24
Sep 19, 2005 10:27 AM
