valve adj. w/advanced/retarded cams????
well, after a month of every company i dealt w/ flaking & lagging on me EXCEPT for h-t members: frank@b16a.com,YelLowITR, dr.kimball, ernircars, and a couple other guys, i'm finally putting my head back on. i have 01 itr cams which ill probably advance 2deg./in and retard 1deg./ex. ill get to the dyno sooner or later but for now... i havent heard of a gsr w/ this set-up that hasnt benefited from a lil +in. & -ex.(if u have please post)
i was wondering, when i do the valve adj. w/ the cams advanced & retarded is the valve lash the same??(since the cams r in differnt positions)
or
do i do the valve adj. w/ the cams @ 0, then advance and retard them afterwards??
hmm.. now that i mention it, the ladder of the two seems right, but anyone know for sure??
TIA
or
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filetofit »</TD></TR><TR><TD CLASS="quote">The valves are adjusted completely closed, plus or minus a few degrees won't matter 'cause they are each completely closed for more than 180 degrees of cam rotation. </TD></TR></TABLE>
And because they are closed for 180 deg. or more, does the valve adj. need to be done, at exact TDC for each cylinder (disregarding advanced or retarded timing)? or just close to TDC?
jceltalentoso
Jan 27, 2014 08:54 PM
