vafc question
i'm installing the vafc tonight and i want to know if i can just install wiring, do the intial settings and not have to set anything else. i don't want to mess with anything because i'm driving to maryland tomorrow and it will be dyno tuned on thur. also are there any tips you could give me before i tackle this install? i know how to splice the wires in and all that. the only thing i'm worried about is properly locating wires on the ecu and the ecu removal itself. (i never messed with one, so i'm not exactly sure how to remove it/access the wires)
Not really sure what your question is asking but I believe your asking if you need to change any settings to make it run so you can get to the dyno. To answer your question, no, not necessarily. It'll run fine with the factory Apex'i settings.
