VAFC or P28 chipped?
Old Apr 29, 2003 | 12:58 PM
DC2_Integra's Avatar
Default VAFC or P28 chipped?
i got a OBD2 on my car right now. Which would u recommend between the two? My plans on the motor are:
Skunk2 IM
Skunk2 stage 1 cams
Type R valvetrain parts
Type R pistons
thanks
Old Apr 29, 2003 | 01:18 PM
Al Bundy's Avatar
Default Re: VAFC or P28 chipped? (DC2_Integra)
Get both
Old Apr 29, 2003 | 01:25 PM
eg6ajk's Avatar
if you got cash to spend, then indeed get both. this will allow you to get most out of your chipped ECU.
if you can't then OBDI ecu seems like your best bet. ability to have your vtec, rev limits points set, improve fuel/ignition maps are one of the benefits. and for little under $300 you can have the ECU and harness converter. (check my sig and check out the best buys forum for $125 harnesses from Blown90hatch )
while the VAFC is a good pice all it can do is to adjust fuel maps and set your vtec point.
Old Apr 29, 2003 | 02:10 PM
gaskleppie's Avatar
Default Re: VAFC or P28 chipped? (eg6ajk)
How good is the OBD2 dc2 ecu anyway? Can it give problems when the engine is fully build? Or, How well does the OBD2 ecu learn from modifications?
Old Apr 29, 2003 | 02:16 PM
Default Re: VAFC or P28 chipped? (gaskleppie)
cool!
Old Apr 29, 2003 | 04:53 PM
liquid51's Avatar
hondata s200.
Old Apr 29, 2003 | 06:26 PM
dfoxengr's Avatar
Default Re: VAFC or P28 chipped? (Al Bundy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Al Bundy &raquo;</TD></TR><TR><TD CLASS="quote">Get both</TD></TR></TABLE>
B20inDCinLBC
Apr 14, 2009 01:43 PM
DC2SIR-G
Mar 13, 2006 12:21 PM
TeamDOHCside
May 11, 2004 08:55 AM
fred92htch
Dec 5, 2002 10:35 AM
Pinhead
Feb 6, 2002 12:39 PM
