v-afc problem?...need help
Old Jul 7, 2005 | 07:13 AM
turbochargeb18c's Avatar
BANNED
Default v-afc problem?...need help
well,last night i took out the v-afc out of one of my car and after i took it out,id check to see if im getting any check engine light...i ran a u loop wire on the diagnoes plug...when i did that the check engine light just stays on w/ no code thrown or flashes...so i figure i dont have any check engine light...but when i crank the car on i get a check engine light...wtf!!..so i ran the u loop wire again,but same ****...the check engine light stays on w/ no codes thrown....i know that it suppose to throw o2...and yes i reset the ecu... but nothing...any suggestion...
Old Jul 7, 2005 | 09:07 AM
EE_Chris's Avatar
Default Re: v-afc problem?...need help (turbochargeb18c)
If you took out the VAFC, did you make sure to connect the MAP sensor back up?
Old Jul 7, 2005 | 09:09 AM
BANNED
Default Re: v-afc problem?...need help (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">If you took out the VAFC, did you make sure to connect the MAP sensor back up?</TD></TR></TABLE>
yeap...i hooked the map back up....
Old Jul 7, 2005 | 09:18 AM
EE_Chris's Avatar
And the car was running just prior to you removing the VAFC?
Old Jul 14, 2005 | 05:52 AM
jdmh22luda's Avatar
What is the best way to give a VAFC default settings when u first hook it up?
Old Jul 14, 2005 | 06:45 AM
EE_Chris's Avatar
Default Re: v-afc problem?...need help (jdmh22luda)
Don't people read anymore? Like the instruction manual, for instance?
DCSportEJ1Civic
Oct 28, 2006 09:06 PM
bengay
Jul 22, 2006 05:10 PM
Del_Sol_s
Dec 13, 2005 09:49 PM
South Bay Surfer
Dec 24, 2004 02:15 PM
Tuan
May 13, 2002 03:36 PM
