Using a map sensor in place of an EGR sensor
Old Feb 22, 2008 | 08:07 PM
Brad's Avatar
Default Using a map sensor in place of an EGR sensor
Has anyone tried wiring up a map sensor in place of the EGR and connecting the vacuum line from the 2 wire EGR control sensor to the map? I believe the 2 wire EGR uses the vacuum line to control the lift of the regular EGR valve. No idea if it would work, just curious because the manifold I'm using doesn't have the EGR port.
tony_2018
May 25, 2014 06:48 PM
getupoffthatthan
Oct 15, 2008 03:20 PM
AccordSleeperZzZ
Mar 6, 2007 07:33 PM
