The un-fixable problem??????
Old Oct 10, 2004 | 08:33 PM
WS6Dreams's Avatar
Default The un-fixable problem??????
Ok, I have a 2000 Civic Si, with 9;1 weisco pistons, eagle rods,gsr intake cam, and a Jackson blower that was modded by endyn, along with aem fuel rail, 255 in-tank, and rc 550's. Now my problem is that I was running individual resitors instead of a box. And every so often it seemed that they would go bad and the car would only run off of two cylinders(it felt and sounded like). So I would just slder some new ones in and it would fix that problem. Well I got fed up with doing that every month, so I solderd in a resistor box, and now every once in a while I will throw a misfire code for all 4 cylinders and then about 5 minutes later the car will seem to only run off of two cylinerds. But with the individual resistors I would throw the same codes but the car would run fine. I dont get it........should geta new cap and rotor? I think the problem could also be the injector drivers in the ecu, but if it were those then the car wouldnt run at all. No-one can figure this out. Please help me. Sorry for the length.
Thanks in advance.
-Blake
Old Oct 11, 2004 | 05:35 AM
non-VTEC's Avatar
Default Re: The un-fixable problem?????? (WS6Dreams)
why not ditch the peak hold 550 injectors and get a set of saturated 550's and this way you wont have to worry about resistors......
Old Oct 11, 2004 | 08:51 AM
Jokerluv's Avatar
cylinerds are cool
Old Oct 11, 2004 | 11:47 AM
WS6Dreams's Avatar
Thanks for the advice so far.
ttt
jake[eh2]
Nov 27, 2011 12:59 PM
V3locity
Dec 21, 2009 05:52 PM
aleazyteg123
Jul 30, 2008 05:54 AM
