uberdata: popping at idle
Old Sep 14, 2005 | 02:40 PM
bOOsTiNSoHcVtEc's Avatar
Default uberdata: popping at idle
For some reason the exhaust pops constantly at idle. anyone else going through the same problem with uberdata? what do you guys think i should do? what columns of the lo fuel map should i modify if you think thats the reason behind it? also in the uberdata forum i see that some ppl say change your fuel cut valve to 14 with a stock map.. what does this do exactly and why? I did it and it really didnt change anything so i put it back to 24.
Old Sep 15, 2005 | 03:00 PM
Default Re: uberdata: popping at idle (bOOsTiNSoHcVtEc)
Old Sep 15, 2005 | 09:30 PM
Muckman's Avatar
Moderator in Chief
poping at idle is usually caused by a lean condition.
Old Sep 16, 2005 | 11:53 AM
Default Re: uberdata: popping at idle (Muckman)
can richness cause this also? it smells like its running really rich..
Old Sep 30, 2005 | 06:40 PM
JLHDOHC's Avatar
Thats kinda weird mine did that through out the engine life and I recently blew the head gasket. I pulled the head off and found number 4 piston melting on the outside edges on the intake side it slowly got worse 3-2-1.. We tried tunning out the popping forever nothing.. I am not saying that that was the reason but my car ran great besides that.
Old Sep 30, 2005 | 10:42 PM
Default Re: uberdata: popping at idle (JLHDOHC)
hopefully it isnt that but i did sorta fixed the problem. well for some reason my motors vacuum pressure idle is at 16 so basically it was running hella rich at idle which caused the misfiring popping noise. so all i did was lean out the rpms i wanted in the 16 section and magic happend lol.. the popping stopped. hope this helps some ppl with the same problem..
Spawne32
Engine Management and Tuning
Sep 19, 2010 02:09 PM
quicksilver1689
Sep 29, 2008 01:13 PM
welfarepc
Sep 13, 2007 05:15 PM
Topdawgg
May 13, 2007 05:07 PM
coronadrinker
Oct 9, 2006 05:11 AM
