Type R outer valve springs
Old Feb 24, 2003 | 09:12 AM
Henry HA's Avatar
HAnda-Tech Member
Default Type R outer valve springs
Why do people use a combination of these outer springs with other aftermarket inner springs?Is this a good idea?benefits?Help any one.I am bored and curious
Old Feb 24, 2003 | 09:23 AM
Spade's Avatar
Default Re: Type R outer valve springs (B18C_DC2)
Costs less.
Old Mar 6, 2003 | 07:02 AM
EH2-LS-TURBO's Avatar
Default Re: Type R outer valve springs (Spade)
Costs less.
my brother owns an integra and he uses the same set up just because its cheaper!
Old Mar 6, 2003 | 07:07 AM
Henry HA's Avatar
HAnda-Tech Member
Default Re: Type R outer valve springs (EH2-LS-TURBO)
Costs less.
Wow..thanks EH2-LS-Turbo...sometimes, you knowledge is limitless, You contribute SO MUCH to this forum
I just want to thank you,
Old Mar 6, 2003 | 07:09 AM
Costs less.
my pleasure...i always loved helping people
Old Mar 7, 2003 | 09:49 AM
Henry HA's Avatar
HAnda-Tech Member
So hows ur civic going? I heard u hit high 12's or sumthin last week?
Old Mar 7, 2003 | 09:58 AM
BROOD's Avatar
I'd still search around about this subject. I am not a fan of oem ITR outers and stiff aftermarket inners. You may run into problems.....sometime the cheaper way is not the best thought out way. Just something to consider.
Old Mar 7, 2003 | 04:44 PM
owen_the_soyboy's Avatar
portflow inner springs and ITR outer springs can rev to 10,000 rpm.
ITR inners and ITR outers will only handle 9000 rpm.
some cams require more and some less, but thats the general rule.... its just a good thing that the portflow/ITR setup is cheaper too!
Old Mar 9, 2003 | 07:00 PM
MEANB18's Avatar
Default Re: Type R outer valve springs (owen_the_soyboy)
Is this true then for a bigger cam.. like Toda C's? I've heard it is not good to rev up that high with Portflow inners on Toda C's???
Old Mar 9, 2003 | 09:28 PM
Timmayeg's Avatar
New User
Default Re: Type R outer valve springs (MEANB18)
i sell complete valve springs with inner and outer for both I and E sides for cheaper than most people want for ITR outers
aznromeo069
Mar 16, 2007 09:50 PM
chrisgottigsr
Feb 20, 2006 07:03 PM
integGSR805
Jul 6, 2005 02:27 AM
