type r block with a gsr head??
Old Feb 14, 2004 | 04:26 PM
vecspeed12's Avatar
Default type r block with a gsr head??
i just bought a 01 type r from a hole in the wall dealership. i checked everything out but what i noticed later on was that i currently have a GSR head with a skunk2 manifold. i cant tell what kind of cams i have and also. the car runs strong.and when i did a compression check on it. all 4 cylinders are shooting out 225 psi. i tried doing a search but i cant get my answers...
basically i heard its good for people to use the other way around. which is a gsr block with a type r head. so my question is: how good is this motor? is this faster than a stock type r? and where should be my redline at? i cant tell whats in this motor.
i currently added:
-jdm apexi headers with 2.5 flange.
-spoon test pipe
-apexi n1 exhaust
-real spoon ecu with harness
-spoon drop in filter
this has been stressing me since i realized i was using a p72-2 head.
please help.. thanks
Old Feb 14, 2004 | 05:00 PM
RedlinedVTEC's Avatar
Default Re: type r block with a gsr head?? (vecspeed12)
Whew that's pretty shady. Only way to get to the heart of things is pull things apart and find out, spend a couple hours and pull the cams to see which you have and you may also consider pulling the head to check out which pistons you're running.
Old Feb 14, 2004 | 05:01 PM
^jefs0ng's Avatar
Banned
Default Re: type r block with a gsr head?? (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Whew that's pretty shady. Only way to get to the heart of things is pull things apart and find out, spend a couple hours and pull the cams to see which you have and you may also consider pulling the head to check out which pistons you're running.</TD></TR></TABLE>
Yeah or take it to a place to rip it apart and see everything you're running..
kyleeuuu
Feb 8, 2009 04:16 AM
dayaftertomorrow
Feb 13, 2006 02:03 AM
Sik Wit It Hatch
Nov 11, 2004 08:06 PM
moreno
19
Oct 30, 2003 07:59 AM
B18CRacer
Jan 31, 2002 03:03 PM
