Tweaked ECU VS. AFC
Old Feb 24, 2002 | 02:48 PM
SilentFury's Avatar
Default Tweaked ECU VS. AFC
Which, in your opinion, is the most cost efficent and effective; chipping the brain (or having a shop tune it) or just buying a Air Fuel Controller? I am asking because I own an eg6 on Okinawa and I cant import the car back to the US and I want to limit the mods to ones that I can bring back... no one likes hondas over here
Current mods consist of: I/H/E, test pipe, flywheel/clutch & CTR cams.
Old Feb 24, 2002 | 06:53 PM
Jared's Avatar
Default Re: Tweaked ECU VS. AFC (IhateOkinawa)
go with both, the chipped ECU modifies both your ignition curves and fuel maps, but the AFC will just change fuel mods.
Old Feb 24, 2002 | 06:55 PM
rainforest's Avatar
Default Re: Tweaked ECU VS. AFC (Jared)
i second that you can tweak your fuel map then further raise the fuel or lean out the fuel. the same with the spark.
Lquin
Nov 5, 2011 06:01 AM
SilentFury
Feb 24, 2002 02:55 PM
SilentFury
Feb 24, 2002 02:38 PM
