Turning over but not starting.
Old Sep 3, 2017 | 11:53 AM
Mickle's Avatar
Default Turning over but not starting.
So I'm buying a civic but not paying for it till it's running. I'm pretty sure because the guy before was running a turbo+nos set up the timing is way off, to get it running all i have to do is advance the timing back to normal right? I'm new to the Honda game so sorry if this is an obvious question answer scenario. Just trying not to blow up my car (:
Old Sep 3, 2017 | 08:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Turning over but not starting.
You cannot move the distributor far enough forward or backward (advance or retard) to make the car NOT run... so your suggestion that the timing was "retarded" because of a power adder is flawed. If the mechanical timing is off, it isn't because of a turbo or NOS install. Check the timing belt.
Old Sep 4, 2017 | 07:11 AM
TreyIL's Avatar
Check your timing at the belt like JRCivic1 said and if that's fine then check if you have fuel and spark.
Old Sep 4, 2017 | 07:34 AM
Mickle's Avatar
ok I'm going to work on it here in a minute, I'll try to make sure the timing belt is in the right places. Let you k iw what happens. Appreciate it man.
zx92027xz
Aug 11, 2012 06:47 AM
johnk92
May 13, 2012 08:53 AM
kixcrx
Nov 10, 2006 10:33 AM
98slvrcx
Jul 28, 2002 09:58 PM
