Sensor wiring
Old Sep 4, 2017 | 12:13 PM
tmramsburg's Avatar
Default Sensor wiring
Not sure where to post this. So.... I am slowly swapping a b16 into a 00' cx hatch. I need this car to pass MD emissions, with a Civic SI ecu, OBD2b. Or maby any one can suggest something else. It seems like I need to install a fuel tank pressure sensor which requires wiring from sensor to ecu. So, my question is, where can I buy oem wiring or motorsport wiring. Would be nice to have selection of wiring for future projects.
Thanks
Tim
Old Sep 4, 2017 | 02:02 PM
tmramsburg's Avatar
Default Re: Sensor wiring
I think I found my answer. Tefzel wiring? I found it on amazon. Seems reasonably priced. Does anyone have a inexpensive (not cheaper) solution to automotive wiring. Do I need shielded wiring for fuel tank pressure sensor?
Thanks
Tim
Old Sep 4, 2017 | 04:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It should already be there since you have a '00 Civic. No additional wiring should be necessary at the fuel tank.
Old Sep 4, 2017 | 06:27 PM
tmramsburg's Avatar
You are correct, jut look at Helms. Thanks.
Old Sep 4, 2017 | 08:30 PM
motoxxxman's Avatar
2000 civic is obd2a, not obd2b. I'm wondering why you said that.
Old Sep 5, 2017 | 04:33 PM
TheShodan's Avatar
Moderator
2000 Civic SI is actually OBD2B. OBD2A is from 96-98, 99-01 is OBD2B
Mik3o
Feb 26, 2015 02:53 PM
mrEM1
Mar 13, 2009 03:06 PM
