Tuning..
Old Sep 13, 2005 | 07:21 AM
MenaceL.A.671's Avatar
Default Tuning..
if i set the cam gears on +4 in. and -2ex. what should i set my timing on...16 degree or 0 degreee..
Old Sep 13, 2005 | 08:19 AM
mmuller's Avatar
Mad Scientist
Default Re: Tuning.. (m2slsvtec)
you set it just like you normally would
Old Sep 13, 2005 | 07:14 PM
Default Re: Tuning.. (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you set it just like you normally would</TD></TR></TABLE>
so that means if i mess around with the cam gears i have to set it to 16 btc?
Old Sep 13, 2005 | 07:39 PM
rev-speed's Avatar
yes everytime u change the intake camgear timing will change so u have to reset it to
Old Sep 18, 2005 | 06:27 AM
Default Re: (rev-speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev-speed &raquo;</TD></TR><TR><TD CLASS="quote">yes everytime u change the intake camgear timing will change so u have to reset it to
so reset it to 0 degree or 16 degree???
Old Sep 19, 2005 | 12:12 PM
tgreaves's Avatar
Default Re: (m2slsvtec)
Uhh.. You set your timing back to stock which is 16 degrees BTDC.. If you dont know what to set it to then you shouldnt be messing with it..
And why those cam gear settings, did you hear that from someone else or something?
turbo boost
Apr 15, 2008 04:06 AM
hatchinprogress
12
Feb 24, 2006 01:16 PM
IVI
Apr 9, 2004 09:54 PM
Ek9Max
Feb 15, 2004 01:50 PM
JDMHatch101
10
Sep 30, 2003 05:25 PM
