true or false? lsd question
Old Mar 16, 2003 | 05:32 PM
mckenzie's Avatar
Default true or false? lsd question
hydro b16 lsd will fit into a integra ls tranny?
Old Mar 16, 2003 | 06:34 PM
dfoxengr's Avatar
Default Re: true or false? lsd question (egMee)
true- same as R LSD..and thatll fit.
Old Mar 16, 2003 | 07:24 PM
delslow94's Avatar
Default Re: true or false? lsd question (hybridvteceg)
does anyone have a how to link with pictures on how to do it correctly. i have a honda shop manual but would like to see the steps. thanks
sorry for taking the thread over.
Old Mar 16, 2003 | 08:48 PM
3rdGteg's Avatar
Default Re: true or false? lsd question (delslow94)
If that honda shop manual you're talking about is a "Helm's" then it should be all that u need cuz it includes everything even pics; but if not, get a Helm's cuz it's got step-by-step, pics, etc.
Old Mar 17, 2003 | 02:15 PM
mckenzie's Avatar
what about a ctr lsd?
Old Mar 17, 2003 | 02:32 PM
Katman's Avatar
need more info from you.
What year is your LS tranny?
If its a 92-93/YS1 LS tranny, then you can use a hydro B16 LSD or YS1 LSD (jdm only). Thing is, I'm not sure if the hydro B16 LSD's diameter matches up to a YS1/LS ring gear. That's something you'll have to find out. If it does NOT fit, then you'll have to use the B16 final drive ring gear, which means you will UP your final drive ratio to 4.40 vs. 4.266.
If you own a 90-91 LS tranny (not sure of the tranny code, but think its an S1), you'll have use an LSD from a JDM B16A Y1 tranny, and again, you'll have to see if that specific LSD will bolt up to a 90-91 LS ring gear....
[Modified by Katman, 3:35 PM 3/17/2003]
Old Mar 17, 2003 | 06:32 PM
mckenzie's Avatar
Default Re: true or false? lsd question (Katman)
i have a 94-95 ls tranny
Old Mar 17, 2003 | 09:05 PM
Katman's Avatar
ok then.. you're in good hands.....AlLstate.... ahem....I mean yeah, an ITR or CTR LSD will bolt onto your LS ring gear. A hydro B16 LSD will most likely NOT fit on a hydro LS ring gear since the diameter of the LS ring gear is bigger than that of a hydro B16's ring gear. So to remedy that you'd have to use the hydro B16A final drive ring gear and possibly the final drive shaft.
HondaAddict91
Transmission & Drivetrain
14
Jan 9, 2017 07:11 PM
stalyun
Southeast (Sales)
Oct 19, 2009 08:14 PM
b18tegg
Nov 27, 2007 07:12 PM
ZenDynasty
Mar 27, 2005 09:19 PM
