trouble finding tdc on my d16y8
Old Jan 29, 2006 | 11:40 AM
92civeg's Avatar
Default trouble finding tdc on my d16y8
the marks on the cam gear seem to be off .......and i cant find the mark on the block for the timing belt pulley..i have a chilton for the 84-95 civic/crx...but i don't see anything in that manual about a mark on the timing belt pulley
here are some pics any tips would be very much appreciated
Old Jan 29, 2006 | 12:27 PM
rudebwoy's Avatar
take out your number one spark plug, stick a long screwdriver, or anything long enough to reach the piston, rotate your crank with a 19mm socket and ratchet by you crank pully until the screwdriver is all the way up, you will know when you hit TDC, because the screwdiver will start going down when you pass it. it works all the time, try it
Old Jan 29, 2006 | 12:28 PM
rudebwoy's Avatar
Default Re: (rudebwoy)
edit in your pics your crank is already at TDC see the woodruff key is straight up?
everything look fine
Old Jan 29, 2006 | 02:43 PM
92civeg's Avatar
shouldnt there be an arrow on the oil pump?
Old Jan 29, 2006 | 05:25 PM
92civeg's Avatar
Default Re: (92civeg)
cant be this hard
Old Jan 29, 2006 | 05:27 PM
86si's Avatar
yes there is a line on the oil pump. look hard and you will see
TheCrimsonGhost666
Aug 21, 2010 09:49 PM
HBK
Sep 1, 2005 09:37 AM
tibs
Jun 12, 2005 01:56 PM
Jonathan_ED3
Apr 12, 2003 02:57 PM
Jonathan_ED3
Apr 12, 2003 02:55 PM
