Transmission Question
Old Dec 8, 2003 | 07:25 PM
9200RPM's Avatar
Default Transmission Question
I need a diagram on whats what in a B series transmission...thanks...
Old Dec 9, 2003 | 08:09 AM
Wes V's Avatar
Default Re: Transmission Question (TurboB16aEG)
You will need the factory (Helms) manual for the year of the transmission.
I just got done rebuilding a YS1 and the manual was well worth it!!!!! There are all sorts of diagrams (not just one) that are needed.
Over my (extensive) years, I've rebuilt all sorts of transmissions (non-professional) and the Honda was the first that I've found where you really NEED the manual. They are not hard to do, but the manual helps get everything in the correct orientation.
Wes
Old Dec 9, 2003 | 09:58 PM
9200RPM's Avatar
Default Re: Transmission Question (Wes V)
Cool thanks for the info...Do you know where the easiest place I get a Helms...I checked there web site and couldnt find a honda specific manual..
Old Dec 10, 2003 | 07:52 AM
Wes V's Avatar
Go to "helminc.com" and then to to the section for "aftermarket". You should find what you need there.
If that's where you already went, then try doing a search for any year that the transmission was made. As an example, the YS1 that I've got was made in both 92 and 93, so either manual would work.
I ended up using a 95 Integra manual and it was close enough to get the job done. Keep in mind that in 95, the clutch release was hydro, where as the 93 transmission I had was cable. As a result, I ended up using an old Haynes Civic manual for that area (the transmission wasn't all together when I bought it).
I don't think that Helms covers JDM cars.
If there is anything else that you think I can help you out with, e-mail me; wesvn@chevelles.com
Wes
Old Dec 10, 2003 | 09:36 AM
cxSHOE's Avatar
get it in my sig. and pass the news around its been there for a year and a half. spread the knowledge around
Old Dec 10, 2003 | 12:42 PM
kwik92hb's Avatar
Default Re: Transmission Question (cxSHOE)
Great Info
Modified by kwik92hb at 9:53 PM 12/10/2003
Old Dec 10, 2003 | 07:09 PM
9200RPM's Avatar
Super helpfull...thanks a lot...
flybe90
Transmission & Drivetrain
11
Nov 27, 2016 12:37 AM
JimmyM86
Honda Civic (2001 - 2005)
Dec 26, 2007 08:36 PM
Eglifestyle
Sep 16, 2005 10:27 PM
Kellindal
Nov 30, 2004 01:02 PM
Shardie
Oct 22, 2003 12:11 PM
