Transmission Power lost percentage?
Old Sep 22, 2002 | 08:28 AM
275Performance's Avatar
Default Transmission Power lost percentage?
Does anyone know the powertrain loss percentage of honda transmissions? I couldn't find any bone stock base whp to use for calculating. Or I need the base whp of b18b. Thanks a lot.
Old Sep 22, 2002 | 09:50 AM
spikius's Avatar
Default Re: Transmission Power lost percentage? (TDCImports)
I've heard and read and seen kinda supported by dynos that b-series manuals tend to lose about 15%, and b-series autos lose about 30%. It's only a rough figure though.
Old Sep 22, 2002 | 10:10 AM
TimoneX's Avatar
New User
I use 16% total drive train loss for my calculations for my '96 GSR. This number seems to be a good rough estimate. If you look at stock Integras on a wheel dyno it seems to come out about right, assuming Hondas #s for crank HP are accurate. The exception seems to be 98+ GSRs which seem to come out to 22%. They dyno near 133ish, so if the 170HP claimed by Acura is accurate that'd be a 22% loss. Something seems fishy with OBDIIb+.
Old Sep 22, 2002 | 10:16 AM
Default Re: Transmission Power lost percentage? (TimoneX)
Thanks a lot. I'll try using 17-16% for my b18b mannual tranny. How much do lighter flywheels help you think? For example the JUN one?
Old Sep 22, 2002 | 10:57 AM
TimoneX's Avatar
New User
I'm going with the Exedy flywheel/clutch combo when my original clutch croaks. IT WON'T DIE! I think the Jun is chromoly and around 9lbs like the Exedy, if I recall rightly. They remove a significant load from the engine and allow faster revving. This is clearly beneficial for our cars since they don't make allot of power at low engine speeds. I've driven a Honda(not teg) with a lightened flywheel and it did rev very quickly, which to me made it more fun to drive. I haven't seen much of anything to quantify the performance gained by replacing the stock flywheel with a lighter aftermarket one however, I fail to see how it could not improve performance if you're getting into your powerband sooner. I wouldn't expect a huge boost though, merely a change in character and perhaps longer engine(bearing) life.
96tegsr
Dec 9, 2004 07:21 AM
Starscream
Jul 15, 2004 05:34 PM
ID_ten_T
Mar 6, 2004 11:04 PM
Sima
Jul 2, 2002 11:42 AM
