transmission issues...
Old Nov 4, 2013 | 03:31 PM
kou-integra98's Avatar
Default transmission issues...
Sup HT have a 98 gsr I haven't drove it for a while ever since i started working on my 00 gsr, but I drove it today because I need a car to go places and I went to the store and my uncle house and couple of my friend house it was fine... but on the way to get my new tires going in gears is starting to get hard like I have to kinda force it in... and when I slowly press on the clutch half way the clutch pedal was shakes like hell... when I'm at stop lights and put it in neutral car is fine... but when I clutch and put it in any gear (while still stepping on the clutch getting ready to take off on a green light) the car start shaking... as if it's gonna die or it wants to go... its not really noticeable unless you're driving. Could it be the clutch? or am I running out of transmission fluid? or something else... It doesn't make any noises at all... help plz..
Old Nov 4, 2013 | 04:08 PM
midwest aaron's Avatar
Default Re: transmission issues...
kinda sounds like something is out of spec, tight gear clearance or something is being welded together. I would check to see if your leaking trans fluid, or if your low. at least from what it sounds. I had a customer that had that happen. the reverse synchro welded itself to the spacer.
Old Nov 4, 2013 | 04:50 PM
fcm's Avatar
fcm
Old Fart
Check transmission oil/fluid level, sounds like it is low. 94
Old Nov 4, 2013 | 08:49 PM
Yeah I'll get it check out and see what happens
Old Nov 4, 2013 | 09:28 PM
Turbo-LS's Avatar
Sounds like clutch pedal is out of adjustment and seeing it just started to happen it could also be a leaky slave or master cylinder and the clutch is not fully disengaging.
Old Nov 5, 2013 | 09:56 AM
alright well i checked it out and turns out i'm leaking transmission fluid from under the tranny where the bolts are, some of them are lose, not sure how... but I tighten them up, but it was slowly leaking not to the point where it drips... I've drain the transmission fluid and it's very low... so I'm planning to get some and just fill it up... not sure what are good transmission fluid but yesterday i went to pepboys and got some valvoline 80w90, is it alright to use these?
Old Nov 5, 2013 | 10:03 AM
KidDxbOrI's Avatar
80w90 idk lol I have d15b2 and my trans takes 10w30 soo maybe it's different maybe it's not I would double check on that
Old Nov 5, 2013 | 11:34 AM
isn't 10w30 motor oil? i was talking about transmission fluid.
Old Nov 5, 2013 | 12:00 PM
kyden's Avatar
the transmission fluid is equivalent to 5w30 (the older transmissions actually call for that), but I would just go to Honda or acura and get some MTF.
Old Nov 5, 2013 | 03:46 PM
Yeah, we'll I replace/refill the transmission fluid and drive it for a while it's still the same... what can it be then? the clutch?
Old Nov 6, 2013 | 06:11 AM
fcm's Avatar
fcm
Old Fart
Nothing left but to drop the transmission so you can inspect the clutch/pressure plate/flywheel/TO bearing. 94
Old Nov 6, 2013 | 09:59 AM
yeah that's my only option left.... well see whatups
Old Nov 6, 2013 | 02:54 PM
get Honda mtf, 80-90 is way too heavy for that.
levifps
Mar 27, 2007 12:23 PM
devilpuppy
Jan 18, 2005 05:53 PM
Dc2 Powered
Aug 22, 2004 08:09 PM
hybrider
Aug 3, 2002 06:20 PM
baonest
Jun 26, 2001 03:57 PM
