Transmission code question. do i have a GSR tranny?
Old Oct 26, 2008 | 12:57 AM
helldriver88's Avatar
Default Transmission code question. do i have a GSR tranny?
whats the GSR transmission code? judging by the VIN plate i think i ended up with an LS tranny.
GSR is DC2 correct? well the VIN plate on my tranny says DC4. wich would indicate B18B1, right?
so to properly verify this i need to know the transmission code for an LS and a GSR tranny.
Old Oct 27, 2008 | 08:31 AM
Default Re: Transmission code question. do i have a GSR tranny? (helldriver88)
so...tranny code anybody? i'd like to identefiy my transmission....
Old Oct 27, 2008 | 01:22 PM
Honda Bull's Avatar
Not quite sure, but can you drive it to let us know what RPM it's turning in a specific gear at a specific speed?
Old Oct 28, 2008 | 08:16 AM
Relic1's Avatar
depending on the year...
DC2 = C1/C5
DC4 = B1
but that's doesn't mean that's what's in the case.
Is there anything stamped on the side of the trans? larger black lettering up/left from the clutch slave. (Y80? S80?)
what do you see when looking through the axle holes?
Old Nov 2, 2008 | 03:40 AM
Default Re: (Relic1)
just found out its an S80 with a Phantom grip LSD. just not sure what motor its ment to match up with.
Old Nov 2, 2008 | 02:36 PM
gsrstick's Avatar
im noob ,but gsr also db8w/s80
Old Nov 3, 2008 | 07:56 AM
neoc03's Avatar
What out for that Phanton Slip!
Old Nov 3, 2008 | 05:53 PM
Default Re: (neoc03)
say what?
Old Nov 7, 2008 | 03:34 AM
Default Re: (helldriver88)
bump for a lil more info
Old Nov 8, 2008 | 02:42 AM
uniseriate's Avatar
Run the VIN at carfax.com and it will tell you the make and model for free.
Old Nov 8, 2008 | 11:36 AM
Default Re: (uniseriate)
i already know the make model and year cause i already read the vin. what i want to know is what a S80 is. if its a GSR or an LS. the VIN and the transmission code are on two separate parts of the transmission. knowing the transmission was taken apart someone could of just as easily slipped a GSR gear housing on to an LS clutch housing so basically what im saying is the VIN means nothing at this point its all on the gear housing. so S80. what is it?
Old Jul 2, 2017 | 03:48 PM
Ruben Guevara's Avatar
Is the S80 3060459 a LS or gsr ??
julianbc2
Mar 4, 2009 12:42 AM
LuMop
Aug 10, 2006 04:51 PM
Tuan
Aug 19, 2002 07:57 PM
The Rob
Jul 14, 2002 11:39 PM
