Tranny keeps going low on OIL
Old Feb 22, 2004 | 08:08 AM
revv's Avatar
Default Tranny keeps going low on OIL
I've done everything. I've changed all the plugs "drain and fill" also changed the the rubbers that go in the tranny hole where the shafts plugs in "forgot the proper name" i also even chaged my passenger side drive shaft thinking it may help. oil is only on the passenger side,
i'm still loosing oil and no aparent cracks anywhere. stupid 5th gear pops out when i run low. driving me nuts.
Cable trany is a Y1 LSD
Your help i much appreciated
Old Feb 22, 2004 | 09:06 AM
acy76's Avatar
Default Re: Tranny keeps going low on OIL (revv)
If the oil is leaking where the axle goes in, make sure the axle is clipped in securely. You may need to tap it in lightly to seat the clip.
Old Feb 22, 2004 | 03:37 PM
revv's Avatar
Default Re: Tranny keeps going low on OIL (acy76)
not even sure where its leaking from....
Kid-jdm-teggy
Transmission & Drivetrain
Sep 10, 2013 08:41 PM
killacam661
Jul 25, 2007 08:25 PM
revv
Feb 22, 2004 05:45 PM
bossman032
Oct 9, 2003 09:24 PM
serious
Apr 3, 2003 06:46 PM
