tranny going bad?
Old Nov 13, 2009 | 02:12 PM
ninjaturtleEG's Avatar
Default tranny going bad?
So i've always had a grind when shifting up to 3rd gear but it never bothered me. Recently i've been hearing a weird rotating noise, kinda like a helicopter, when driving and sometimes when stopped at a red light and idling i'd hear a weird clunking noise. Its a cable tranny in my 93 integra. My car still drives perfect, just making me uneasy with all the weird noises. Whats going on? Do i need a new trnsmission soon? i can get a used one on craigslist for around $300. would this be something that i can do by myself? also stupid question but do i need to pull the motor to swap trannies? btw its stock b18a1 if that helps. Thanks
Old Nov 13, 2009 | 02:22 PM
fcm's Avatar
fcm
Old Fart
Default Re: tranny going bad?
Yes it's the tranny, not sure if you have to pull the engine on a G2, it is not required on a G3.
I pull mine once a year to replace the springs on the Phantom Grip LSD, no biggie, easy as pie with a hoist.
Old Nov 13, 2009 | 02:30 PM
burningrex's Avatar
you don't have to pull the motor to take out the transmission on you 93 integra... it's not that hard but you should get a friend to help you...
Old Nov 13, 2009 | 02:34 PM
^^thanks for the inputs. also as far as compatibility goes, will a b16 cable trans bolt right on?
Old Nov 13, 2009 | 02:50 PM
burningrex's Avatar
yes it will.. the gears are shorter too so it should be more fun to drive...
good luck man
Old Nov 13, 2009 | 02:51 PM
Glock17's Avatar
Any B-Series cable tran will fit.
a1320honda
Transmission & Drivetrain
Jun 6, 2013 01:05 PM
civic ef
Apr 23, 2012 09:10 PM
JDM_SOHC
11
Apr 21, 2006 09:21 AM
