tranny build up
Old Nov 6, 2003 | 05:25 PM
prestonpark's Avatar
Default tranny build up
rite now i have a 99 b16a tranny i wanna put a type r diffrential lsd in there with the jdm 98 type r final drive 4.7
will it work or i have to buy some other parts to make it fit in the b16a tranny
wat else is perform when doing this or will this cut it for the parts list let me know
asap
Old Nov 7, 2003 | 08:13 AM
Default Re: tranny build up (civic2003)
anyone please
Old Nov 7, 2003 | 01:08 PM
_unknown_'s Avatar
From what I found out when I was asking the same question...
In order to run an ITR LSD, you will need an ITR/GSR final drive. So you might as well use the JDM ITR FD.
You might also have to modify the inside of the tranny casing to get the differential to fit. This entails snapping off some thin aluminium fins.
HTH
Old Nov 7, 2003 | 02:44 PM
Default Re: tranny build up (garth)
so all i basicaly need is the type r final drive that it and shave some medal for the casting
Old Nov 7, 2003 | 02:47 PM
iwhichisme's Avatar
all of those things will work perfectly in your tranny, but as mentioned earlier. Make sure you have the final drive kit, as far ast the input shat, etc.
chad
Nov 13, 2003 07:44 PM
NightHawkC5
Mar 26, 2003 02:05 PM
EkREV
Jan 25, 2002 11:56 PM
