Trannsmission Spinning.
ok, so i finally got my h22 to start.
The axles are not it on anything. its just the motor in with the 2 side mounts.
So it starts and the part where you slide your axles in, spin. WHen the car is in neutral, and when the clutch is pressed down. Is it supposed to be that?
. I thought when its in neutral its supposed to be still? Or is it the tranny fluid that is being spun by the crank?
Another thing is. The F22 tranny is supposed to take in 1.9 liters of fluid. only 1.4 fit in, and then it started pouring out the top. Is this ok? Obviously i put it in before i started it. After i started it, and then turned it off, I decided to take out the fill bolt to see if maybe some got used up somewhere(sorta like the engine oil and filter), and it poured out a little. Is this fine?
Edit: The speedo also reads this. Like it shows 10-15 MPH in it
. I thought when its in neutral its supposed to be still? Or is it the tranny fluid that is being spun by the crank?Another thing is. The F22 tranny is supposed to take in 1.9 liters of fluid. only 1.4 fit in, and then it started pouring out the top. Is this ok? Obviously i put it in before i started it. After i started it, and then turned it off, I decided to take out the fill bolt to see if maybe some got used up somewhere(sorta like the engine oil and filter), and it poured out a little. Is this fine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnD1079 »</TD></TR><TR><TD CLASS="quote">ok, so i finally got my h22 to start.
Edit: The speedo also reads this. Like it shows 10-15 MPH in it</TD></TR></TABLE>
its normal if the axles arent in and its spinning..once the car is on the ground and axles are in.. it'll be fine
its supopose to spill out alittle..(assuming your speaking of a M/T not a A/T)
ZCMeGone
10
Jun 25, 2007 08:01 AM
