TPS (throttle position sensor)
Old Dec 9, 2001 | 02:55 PM
1sick4door's Avatar
Default TPS (throttle position sensor)
i need to know what the output voltage lead for the TPS is for a 98 LS motor in my 97 hatchback,...the three wires are green with black stripe,...red with black stripe,...and yellow with green stripe,..im hooking up a zex nitrous kit and i need to know which wire is the output voltage lead,..need info rather quickly,...i lost my manual,...info would be appreciated
Old Dec 9, 2001 | 09:09 PM
CivicFerio's Avatar
Default Re: TPS (1sick4door)
most of the sensors run on a 5V reference voltage.. hook up a DVOM on 2 of the 3 wires, you have to play around to get the right combination.. You should read .5 at idle and about 4.5V at WOT, some cars it's the other way around.
Charleston
Old Dec 9, 2001 | 10:05 PM
1sick4door's Avatar
Default Re: TPS (CivicFerio)
thanx ..but i already finished...
Dealer Leaf
Jan 7, 2007 12:31 PM
dohc_profile
Nov 27, 2006 07:26 AM
d16rice
Apr 17, 2005 10:51 AM
Max_lude
Feb 22, 2003 08:06 AM
