TPS question
Old Nov 24, 2008 | 09:02 PM
jdmkid_82's Avatar
Default TPS question
could a TPS still bad w/ out throwing a code?// The issue im having is my d16z6 feels like its climbing up hill at low rpms. When at idle it seems to b ok til i some what feather the gas and it drops real low to where it wants to stall out but it doesnt, and i would have to advance the timing a little bit for it to idle somewhat better.
ive done these so far
-replace whole dizzy
-plugs and wires
-different IAVC
-fuel filter\
-air filter
-cleaned out my TB
-timing TDC is dead on
the one thing i did notice is while i was spraying soapy water that there is a leak through the TPS gasket (by throwing some bubbles after i pressed the throttle and created pressure through there).. hope i can shed some light w/ this
Old Nov 24, 2008 | 09:05 PM
onepoint6i's Avatar
have you done a leak down on the engine..or at least checked the compression?
Dylanthoms
Apr 24, 2018 08:52 PM
Rob.
Jul 15, 2009 01:26 PM
xxelmanxx
Honda Civic (2001 - 2005)
Apr 23, 2008 09:01 PM
vrrodri
Sep 19, 2007 08:04 AM
Gr8terper4mance
Feb 21, 2006 04:52 AM
