TPS problem
Old Mar 24, 2003 | 04:04 PM
dphi's Avatar
Default TPS problem
I've been having this problem for a few weeks not and I'm truly at a loss.
First of all, a little background. The car is a 94 Civic EX with a 98 GSR swap. A few weeks back, my friend and I had to pull the motor out to re-thread the holes for the motor mount. When we were pulling the motor out, two of the prongs for the TPS broke off. Luckily, my friend had a spare TPS off his old d-series motor so we threw that in.
So now the motor's back in and everything's good except that I can't get the right voltage off the TPS. Adjusting it fully clockwise (I think it's CW anyway, could be CCW) gives a voltage of 3.4 volts or something at WOT and nothing at idle. In fact, it doesn't show any voltage at all untill the throttle is opened around 40%. Turning it the other direction drops the voltage till it gets to like 2.5 volts or so at WOT.
I've tried 2 different TPSs (one of which was straight out of a friend's car, where it worked fine) and changed the plug as well, nothing seems to make a difference. I've reset the VAFC as well. I really don't know what else it could be, the only thing I haven't tried is a different ECU. Any suggestions here?
Old Mar 25, 2003 | 11:22 AM
dphi's Avatar
Default Re: TPS problem (dphi)
Bueller?
Old Mar 25, 2003 | 11:53 AM
Katman's Avatar
try setting it in the middle position...that seems to work for me, whenever I had to adjust my TPS sensor for whatever reasons. Also, take a look at the TPS upclose, usually you can see a sort of dirty outline of the washers that hold the TPS in place...try to match up the screws to the those ghostly washer outlines...
Old Mar 25, 2003 | 12:07 PM
Lsos's Avatar
What's with you and the TPS reports?
Didn't you get the memo?
Old Mar 25, 2003 | 12:36 PM
dfoxengr's Avatar
Default Re: TPS problem (Lsos)
haha was about to say the same thing...
have them on my damn desk in the morning
Old Mar 25, 2003 | 01:05 PM
Katman's Avatar
mmmmmmkaay, yeeeaaaah.....
"Lumburg, is all that is evil and souless at Inninet"
Old Mar 25, 2003 | 03:25 PM
19924ws's Avatar
Default Re: TPS problem (Katman)
I was having a prob with my TPS and thought it was the sensor, but it was actually the plug that goes into it. There are 3 wires that go into it. The yellow one is the voltage wire and mine was got ripped out some how..... I know I did it bec no one else works on it, but I can't remember for the life of me when I would have yanked it it that hard. Anyway, I stated having probs now and then before the wire came completly off. So maybe the low voltage is a partial tear. Check that out too. Mike
Old Mar 29, 2003 | 01:24 PM
dphi's Avatar
Sorry to bump this thread again, I didn't see the replies until just now.
Middle position doesn't work for me either. The highest voltage I can get is 1.5V too low, and that's in the fully CW position.
Yeah, like I said, I already changed the plug once and it didn't help. Now that I think about it though, I should probably trace those wires as far back as I can.
Tizzakowack
Dec 12, 2008 02:06 PM
My97Prelude
Aug 8, 2008 01:52 PM
Turbo_y8
Aug 27, 2007 12:03 PM
bigizsosexy
May 18, 2006 07:06 AM
titan2nv
14
Feb 10, 2005 03:53 PM
